Ana içeriğe geç
Dell Inspiron 15-7537 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7537 RAM Replacement, Bottom Case: adım 1, 1 resimden 1.
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 RAM Replacement: adım 3, 1 resimden 1.
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 RAM Replacement, RAM: adım 4, 2 resimden 1. Dell Inspiron 15-7537 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Gently pull apart clips on the ends of the memory module until the memory module pops up.
  5. Dell Inspiron 15-7537 RAM Replacement: adım 5, 1 resimden 1.
    • Pull the RAM out at a 45 degree angle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jean Whitmore
984 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 2,357
