Ana içeriğe geç
Dell Inspiron 15-7537 Wireless Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: adım 1, 1 resimden 1.
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: adım 2, 1 resimden 1.
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: adım 3, 1 resimden 1.
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: adım 4, 2 resimden 1. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: adım 4, 2 resimden 2.
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: adım 5, 1 resimden 1.
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: adım 6, 1 resimden 1.
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Jean Whitmore
984 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 3,649
