Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The CPU fan makes sure your CPU does not overheat. This guide shows the process of removing the CPU fan from the Dell Inspiron 15-7547.
Parçalar
Hiçbir parça belirtilmedi.
  1. Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Use a spudger to pry up and loosen the back cover.
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Remove the two 5.0 mm-long Philips #0 screws from the fan. The screw marked in orange will remain captive to the fan.
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  4. Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan. Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  5. Lift the fan out of the chassis.
    • Lift the fan out of the chassis.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 286
