Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Use a spudger to pry up and loosen the back cover.
Remove the back cover.
Remove the two 5.0 mm-long Philips #0 screws from the fan.
The screw marked in orange will remain captive to the fan.
Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
