Ana içeriğe geç
Dell Inspiron 15-7547 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  4. Dell Inspiron 15-7547 Hard Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7547 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  5. Dell Inspiron 15-7547 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lift the hard drive out of the chassis.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 670
