Giriş
This guide shows the process of removing the keyboard from the Dell Inspiron 15-7547.
Neye ihtiyacın var
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
Orient the computer so that the hinge for the display facing away from you.
Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
Remove the two 5.0 mm-long Philips #0 screws from the fan.
The screw marked in orange will remain captive to the fan.
Unlatch the ribbon cable by pulling the white release up.
Hold the blue flap and pull to unplug the cable.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
I'm trying to source the 22 , 2.0 mm-long screws that connect the keyboard to the chassis but I dont know what the correct specifications to look for, can someone please help?
