Ana içeriğe geç
Dell Inspiron 15-7547 LCD Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7547 LCD Assembly Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 2, 1 resimden 1.
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: adım 3, 2 resimden 1. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: adım 3, 2 resimden 2.
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 5, 2 resimden 1. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 5, 2 resimden 2.
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  6. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: adım 6, 3 resimden 1. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: adım 6, 3 resimden 2. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: adım 6, 3 resimden 3.
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  7. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 7, 3 resimden 1. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 7, 3 resimden 2. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 7, 3 resimden 3.
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  8. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 8, 3 resimden 1. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 8, 3 resimden 2. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 8, 3 resimden 3.
    • Raise the left and right hinges.
  9. Dell Inspiron 15-7547 LCD Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the LCD display assembly from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 754
