Giriş
Use this guide to remove the motherboard on a Dell Inspiron 15-7547.
Neye ihtiyacın var
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
Remove the two 5.0 mm-long Philips #0 screws from the fan.
The screw marked in orange will remain captive to the fan.
Unlatch the ribbon cable by pulling the white release up.
Hold the blue flap and pull to unplug the cable.
Bir başkası bu kılavuzu tamamladı.
