Ana içeriğe geç
Dell Inspiron 15-7547 RAM Replacement
Neye ihtiyacın var
    1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: adım 1, 1 resimden 1.
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Close the display and flip the laptop on its back.
      • Loosen the ten 5.0 mm-long Phillips #0 screws.
      • The four screws marked with orange will remain captive to the cover.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15-7547 RAM Replacement: adım 2, 1 resimden 1.
      • Use a spudger to pry up and loosen the back cover.
      • Remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 15-7547 RAM Replacement, RAM: adım 3, 3 resimden 1. Dell Inspiron 15-7547 RAM Replacement, RAM: adım 3, 3 resimden 2. Dell Inspiron 15-7547 RAM Replacement, RAM: adım 3, 3 resimden 3.
      • Remove the plastic heat spreader that covers the RAM sticks.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 15-7547 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7547 RAM Replacement: adım 4, 2 resimden 2.
      • Release the clamps on each side of the RAM sticks by pushing away from the center.
      • When done properly the RAM stick should pop up.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 15-7547 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 15-7547 RAM Replacement: adım 5, 2 resimden 2.
      • Pull the RAM stick in a straight line out of the socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 640
