Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Close the display and flip the laptop on its back.
Loosen the ten 5.0 mm-long Phillips #0 screws.
The four screws marked with orange will remain captive to the cover.
Use a spudger to pry up and loosen the back cover.
Remove the back cover.
Orient the computer so that the hinge for the display facing away from you.
Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
Remove the wire connecting the left speaker to the right speaker.
Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
Bir başkası bu kılavuzu tamamladı.
