Ana içeriğe geç
Dell Inspiron 15-7548 Power Port Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7548  Power Port Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 15-7548  Power Port Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548  Power Port Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-7548  Power Port Replacement: adım 2, 2 resimden 2.
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548  Power Port Replacement, Power Port: adım 3, 2 resimden 1. Dell Inspiron 15-7548  Power Port Replacement, Power Port: adım 3, 2 resimden 2.
    • Grab the wires and lightly pull to remove the power port from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 396
