Ana içeriğe geç
Dell Inspiron 15-7548 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-7548 Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: adım 6, 1 resimden 1.
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: adım 9, 1 resimden 1.
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: adım 10, 1 resimden 1.
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the motherboard.
Sonuç
Michael Nunez
325 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Beck Spring 2022 IUPUI, Team 3-3, Beck Spring 2022 üyesi
IUPUI-BECK-S22S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 716
