Ana içeriğe geç
Dell Inspiron 15-7548 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7548 RAM Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 15-7548 RAM Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-7548 RAM Replacement: adım 2, 2 resimden 2.
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Pull the clips away from the side of the RAM stick.
  4. Dell Inspiron 15-7548 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7548 RAM Replacement: adım 4, 2 resimden 2.
    • Lift the RAM up and away from the motherboard.
  5. Dell Inspiron 15-7548 RAM Replacement: adım 5, 1 resimden 1.
    • If there is a second RAM stick, pull the clips away from the side of the RAM stick.
  6. Dell Inspiron 15-7548 RAM Replacement: adım 6, 2 resimden 1. Dell Inspiron 15-7548 RAM Replacement: adım 6, 2 resimden 2.
    • Lift the RAM stick up and away from the motherboard.
Sonuç
Michael Nunez
325 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Beck Spring 2022 IUPUI, Team 3-3, Beck Spring 2022 üyesi
IUPUI-BECK-S22S3G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 374
