Ana içeriğe geç
Dell Inspiron 15-7548 Speaker Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7548 Speaker Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 15-7548 Speaker Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Speaker Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-7548 Speaker Replacement: adım 2, 2 resimden 2.
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Speaker Replacement, Battery: adım 3, 2 resimden 1. Dell Inspiron 15-7548 Speaker Replacement, Battery: adım 3, 2 resimden 2.
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Speaker Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7548 Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Remove the ribbon cable by pulling it out.
  6. Dell Inspiron 15-7548 Speaker Replacement: adım 6, 2 resimden 1. Dell Inspiron 15-7548 Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the compression caps by using the spudger.
  7. Dell Inspiron 15-7548 Speaker Replacement: adım 7, 1 resimden 1.
    • Untangle the wire from the plastic clips and remove the speakers from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 837
