Ana içeriğe geç
Dell Inspiron 15-7559 Back Panel Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7559 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Back Panel Replacement: adım 2, 3 resimden 1. Dell Inspiron 15-7559 Back Panel Replacement: adım 2, 3 resimden 2. Dell Inspiron 15-7559 Back Panel Replacement: adım 2, 3 resimden 3.
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Back Panel Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-7559 Back Panel Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-7559 Back Panel Replacement: adım 3, 3 resimden 3.
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
Sonuç
To reassemble your device, simply press the back panel on until all pins snap back into place and then screw the back panel back on.
3 farklı kişi bu kılavuzu tamamladı.
Trenton Greevebiester
1.536 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 üyesi
UWT-LINER-F17S3G2
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 3,257
