Ana içeriğe geç
Dell Inspiron 15-7559 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-7559 Keyboard Replacement: adım 2, 2 resimden 2.
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: adım 3, 3 resimden 1. Dell Inspiron 15-7559 Keyboard Replacement: adım 3, 3 resimden 2. Dell Inspiron 15-7559 Keyboard Replacement: adım 3, 3 resimden 3.
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: adım 4, 1 resimden 1.
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Trenton Greevebiester
1.536 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 üyesi
UWT-LINER-F17S3G2
5 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
How to put it back
Using Name - Yanıt
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 42
Her zaman: 6,929
