Ana içeriğe geç
Dell Inspiron 1501 Display Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1501 Display Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1501 Display Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1501 Display Replacement, Battery: adım 1, 3 resimden 3.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Display Replacement, Hinge Cover: adım 2, 2 resimden 1. Dell Inspiron 1501 Display Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Display Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 1501 Display Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 1501 Display Replacement, Keyboard: adım 3, 3 resimden 3.
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Display Replacement: adım 4, 2 resimden 1. Dell Inspiron 1501 Display Replacement: adım 4, 2 resimden 2.
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Display Replacement, Display: adım 5, 2 resimden 1. Dell Inspiron 1501 Display Replacement, Display: adım 5, 2 resimden 2.
    • Close display and flip the laptop upside down.
    • Remove the two 8mm JIS #1 screws on the backplate that hold the display.
  6. Dell Inspiron 1501 Display Replacement: adım 6, 1 resimden 1.
    • From the back of the computer, remove the two screw covers.
    • Remove the two 8mm JIS #1 screws.
  7. Dell Inspiron 1501 Display Replacement: adım 7, 2 resimden 1. Dell Inspiron 1501 Display Replacement: adım 7, 2 resimden 2.
    • Turn the laptop over and open the display.
    • Remove the two 5mm JIS #1 screws on the display hinge.
  8. Dell Inspiron 1501 Display Replacement: adım 8, 3 resimden 1. Dell Inspiron 1501 Display Replacement: adım 8, 3 resimden 2. Dell Inspiron 1501 Display Replacement: adım 8, 3 resimden 3.
    • Disconnect the antenna cables from the Mini-Card.
    • Be careful not to knock the standby switch when disconnecting the cables as it is easily broken.
    • Loosen the JIS #1 screw on the display cable.
    • Pull the pull-tab straight up to disconnect the display cable from the laptop.
  9. Dell Inspiron 1501 Display Replacement: adım 9, 1 resimden 1.
    • Remove the display from the rest of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G4
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 930
