Ana içeriğe geç
Dell Inspiron 1501 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1501 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1501 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1501 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: adım 2, 2 resimden 1. Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 1501 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 1501 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 1501 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 1501 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 1501 Keyboard Replacement: adım 4, 2 resimden 2.
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Don Dao
418 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G4
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,016
