Ana içeriğe geç
Dell Inspiron 1501 Wireless Mini-Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1501 Wireless Mini-Card Replacement, Battery: adım 1, 3 resimden 3.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: adım 2, 2 resimden 1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 1501 Wireless Mini-Card Replacement, Keyboard: adım 3, 3 resimden 3.
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  4. Dell Inspiron 1501 Wireless Mini-Card Replacement: adım 4, 2 resimden 1. Dell Inspiron 1501 Wireless Mini-Card Replacement: adım 4, 2 resimden 2.
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: adım 5, 2 resimden 1. Dell Inspiron 1501 Wireless Mini-Card Replacement, Wireless Mini-Card: adım 5, 2 resimden 2.
    • Remove the two wires from their connections.
    • Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
    • Remove the wireless mini-card from the laptop.
Sonuç
Don Dao
361 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G4
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
I have a computer like this. I have a problem that I have not been able to find a solution too. A few parts that support the screen are broken, and I need to know if I will not be able to replace the CPU in the future should I ever decide to cement these specific parts together.
Let me know if you need any more information!
Peter C.
Peter Chapin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 708
