Ana içeriğe geç
Dell Inspiron 1521 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1521 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Hard Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 1521 Hard Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 1521 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Dell Inspiron 1521 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Locate the four 4 mm Phillips #1 screws that secure the hard drive to the laptop. Each of the screws has a white cylinder next to it.
    • Remove these four screws with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 Hard Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 1521 Hard Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 1521 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Once you've made sure all four screws are removed slide the hard drive out with your hand.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rogelio Ordonez
54 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G47
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 3,523
