Ana içeriğe geç
Dell Inspiron 1521 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1521 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Keyboard Replacement: adım 2, 3 resimden 1. Dell Inspiron 1521 Keyboard Replacement: adım 2, 3 resimden 2. Dell Inspiron 1521 Keyboard Replacement: adım 2, 3 resimden 3.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 1521 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 1521 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Keyboard Replacement: adım 4, 1 resimden 1.
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Keyboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 1521 Keyboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 1521 Keyboard Replacement: adım 5, 3 resimden 3.
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Keyboard Replacement: adım 6, 3 resimden 1. Dell Inspiron 1521 Keyboard Replacement: adım 6, 3 resimden 2. Dell Inspiron 1521 Keyboard Replacement: adım 6, 3 resimden 3.
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nikolaus Powell
426 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G47
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 2,124
