Giriş
This guide explains how to remove and replace the Liquid Crystal Display (LCD), which is also called the monitor or screen.
  1. Rotate the laptop so its bottom is facing up.
    • Rotate the laptop so its bottom is facing up.
  2. Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Find the two small indentations of the sides of the panel covering the power button. Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up. Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Now that the panel is loose simply pull the panel off with your hand.
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel. Remove these screws with a Phillips #1 screwdriver. With the screws removed pull the keyboard up with your hand.
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Locate the connector that links the keyboard to the laptop. Gently pull the connector toward the screen of the laptop with your figers to disconnect it. Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
  7. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  8. Locate the two Phillips #1 screws holding the Wireless Local Area Network (WLAN) panel in place. Remove these two screws with a Phillips #1 screwdriver. Remove the WLAN panel by pulling it up with your hand.
    • Locate the two Phillips #1 screws holding the Wireless Local Area Network (WLAN) panel in place.
    • Remove these two screws with a Phillips #1 screwdriver.
    • Remove the WLAN panel by pulling it up with your hand.
  9. Disconnect the black and white wires attached to the WLAN card by pulling up on the connectors with your fingers. During reassembly, the black and white wires reconnect to the WLAN card near the black and white triangles, respectively. Remove the remaining wires from their protective sleeve by hand.
    • Disconnect the black and white wires attached to the WLAN card by pulling up on the connectors with your fingers.
    • During reassembly, the black and white wires reconnect to the WLAN card near the black and white triangles, respectively.
    • Remove the remaining wires from their protective sleeve by hand.
    • The wires in the sleeve are only used in other Dell laptop models. During reassembly they do not connect to anything so just place them back into the sleeve.
  10. Pull the wires that you disconnected in the previous step through the hole in the top of the laptop. Pull the wires that you disconnected in the previous step through the hole in the top of the laptop.
    • Pull the wires that you disconnected in the previous step through the hole in the top of the laptop.
  11. Detach the Phillips #1 grounding screw with a Phillips #1 screwdriver. Disconnect the display cable by pulling up on the rectangular tab with your fingers. Disconnect the display cable by pulling up on the rectangular tab with your fingers.
    • Detach the Phillips #1 grounding screw with a Phillips #1 screwdriver.
    • Disconnect the display cable by pulling up on the rectangular tab with your fingers.
  12. When disconnecting the camera/microphone cable, pull up by the white plug. Pulling on the cable itself can damage it. Disconnect the camera/microphone cable by prying it upward with the plastic opener tool. Separate the camera/microphone cable from the case by pulling it up with your fingers.
    • When disconnecting the camera/microphone cable, pull up by the white plug. Pulling on the cable itself can damage it.
    • Disconnect the camera/microphone cable by prying it upward with the plastic opener tool.
    • Separate the camera/microphone cable from the case by pulling it up with your fingers.
  13. Remove the two 10 mm Phillips #1 screws from the bottom of the laptop that attach the lid assembly to the laptop with a Phillips #1 screwdriver. Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver. Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the laptop that attach the lid assembly to the laptop with a Phillips #1 screwdriver.
    • Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver.
  14. There is a risk of dropping the lid or base of the laptop, or damaging cables. Make sure no cables are still attached. Remove the lid by pulling it up from the base of the laptop with both hands.
    • There is a risk of dropping the lid or base of the laptop, or damaging cables. Make sure no cables are still attached.
    • Remove the lid by pulling it up from the base of the laptop with both hands.
  15. Locate the six 5 mm Phillips #1 screws connecting the display bezel to the back cover. If there are mylar screw covers or rubber bumpers covering the screws remove them.
    • Locate the six 5 mm Phillips #1 screws connecting the display bezel to the back cover.
    • If there are mylar screw covers or rubber bumpers covering the screws remove them.
    • Remove the six screws with a Phillips #1 screwdriver.
  16. When removing the bezel be careful not to damage it. Removal should be done gently and slowly. Use a plastic opener tool to begin separating the bezel from the display assembly. Move around the edges of the bezel with your hand or a plastic opener tool in order to loosen it from the display assembly.
    • When removing the bezel be careful not to damage it. Removal should be done gently and slowly.
    • Use a plastic opener tool to begin separating the bezel from the display assembly.
    • Move around the edges of the bezel with your hand or a plastic opener tool in order to loosen it from the display assembly.
    • Once the bezel is loose, remove it from the display assembly by hand.
  17. Locate the eight 4 mm Phillips #1 screws (four on each side of the LCD) that secure the display to the assembly. Remove the eight screws with a Phillips #1 screwdriver. Remove the eight screws with a Phillips #1 screwdriver.
    • Locate the eight 4 mm Phillips #1 screws (four on each side of the LCD) that secure the display to the assembly.
    • Remove the eight screws with a Phillips #1 screwdriver.
  18. The LCD display can not be completely removed until the cable attached to the assembly is disconnected. Locate where the LCD display cable connects to the housing. Lift the black tab with your finger or a plastic opener tool.
    • The LCD display can not be completely removed until the cable attached to the assembly is disconnected.
    • Locate where the LCD display cable connects to the housing.
    • Lift the black tab with your finger or a plastic opener tool.
    • Gently pull on the cable with tweezers to disconnect it.
  19. Carefully lift and remove the LCD display with both hands. Carefully lift and remove the LCD display with both hands.
    • Carefully lift and remove the LCD display with both hands.
Sonuç
2 başka kişi bu kılavuzu tamamladı.
Christopher McCormack
42 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G47
5 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Thanks for the easy instructions.
Papadavid
papadavid - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 2,706
