Ana içeriğe geç
Dell Inspiron 1525 Central Control Cover Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: adım 2, 2 resimden 1. Dell Inspiron 1525 Central Control Cover Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: adım 3, 1 resimden 1.
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: adım 4, 3 resimden 1. Dell Inspiron 1525 Central Control Cover Replacement: adım 4, 3 resimden 2. Dell Inspiron 1525 Central Control Cover Replacement: adım 4, 3 resimden 3.
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: adım 5, 3 resimden 1. Dell Inspiron 1525 Central Control Cover Replacement: adım 5, 3 resimden 2. Dell Inspiron 1525 Central Control Cover Replacement: adım 5, 3 resimden 3.
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 3,649
