Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to help you replace the LCD on a Dell Inspiron 1525.
Neye ihtiyacın var
Remove the two 4.00 mm Phillips #1 screws from the battery tray.
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
Gently slide the keyboard towards the display until the tabs on its front side are free.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Disconnect the five antennas from their respective cards.
De-route the antennas from their routing retainers.
Use the pointed side of a spudger to peel the six small rubber feet off the display assembly.
Remove the six 6.05 mm Phillips #1 screws hidden beneath each of the rubber feet.
15 farklı kişi bu kılavuzu tamamladı.
