Ana içeriğe geç
Dell Inspiron 1525 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1525 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 1525 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 1525 RAM Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 1525 RAM Replacement, Bottom Cover: adım 3, 2 resimden 1. Dell Inspiron 1525 RAM Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 1525 RAM Replacement, RAM: adım 4, 3 resimden 1. Dell Inspiron 1525 RAM Replacement, RAM: adım 4, 3 resimden 2. Dell Inspiron 1525 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Push the white tabs on either side of the RAM chip outward. The chip should pop up a little.
    • Carefully remove the RAM chip by pulling it out at a slight vertical angle.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 1525 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 1525 RAM Replacement: adım 5, 2 resimden 2.
    • Remove the lower RAM chip in the same fashion as the upper one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 11,351
