Ana içeriğe geç
Dell Inspiron 1525 Wireless Mini-Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Wireless Mini-Card Replacement: adım 2, 2 resimden 1. Dell Inspiron 1525 Wireless Mini-Card Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: adım 3, 2 resimden 1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: adım 4, 2 resimden 1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  5. Dell Inspiron 1525 Wireless Mini-Card Replacement: adım 5, 2 resimden 1. Dell Inspiron 1525 Wireless Mini-Card Replacement: adım 5, 2 resimden 2.
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 28
Her zaman: 8,998
