Ana içeriğe geç
Dell Inspiron 1526 Heat Sink Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1526 Heat Sink Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1526 Heat Sink Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1526 Heat Sink Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: adım 2, 2 resimden 1. Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the eight 3mm screws from the rear casing of the laptop.
  3. Dell Inspiron 1526 Heat Sink Replacement: adım 3, 2 resimden 1. Dell Inspiron 1526 Heat Sink Replacement: adım 3, 2 resimden 2.
    • Loosen the five captive Phillips #0 screws from the heat sink.
    • Lift the heat sink from the motherboard.
  4. Dell Inspiron 1526 Heat Sink Replacement: adım 4, 2 resimden 1. Dell Inspiron 1526 Heat Sink Replacement: adım 4, 2 resimden 2.
    • Apply a pea-sized amount of new thermal paste to the CPU and GPU.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 34
Her zaman: 232
