Ana içeriğe geç
Dell Inspiron 1526 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Inspiron 1526 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1526 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1526 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Slide the unlock button to the left to release the battery.
      • Slide the battery away from the laptop to remove.
      • The unlock button is located on the bottom of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 1526 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
      • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 1526 Keyboard Replacement: adım 3, 1 resimden 1.
      • Flip the laptop over.
      • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 1526 Keyboard Replacement: adım 4, 1 resimden 1.
      • Carefully lift the control cover up and forward to reveal a single ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 1526 Keyboard Replacement: adım 5, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron 1526 Keyboard Replacement: adım 6, 2 resimden 1. Dell Inspiron 1526 Keyboard Replacement: adım 6, 2 resimden 2.
      • Remove the control cover.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Inspiron 1526 Keyboard Replacement: adım 7, 1 resimden 1.
      • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
      FixBot'a Sor
      Yorum Ekle
    7. Dell Inspiron 1526 Keyboard Replacement: adım 8, 1 resimden 1.
      • Lift the keyboard gently from the top, but do not remove completely.
      • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    8. Dell Inspiron 1526 Keyboard Replacement: adım 9, 2 resimden 1. Dell Inspiron 1526 Keyboard Replacement: adım 9, 2 resimden 2.
      • Remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 445
