Ana içeriğe geç
Dell Inspiron 1526 Webcam Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1526 Webcam Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1526 Webcam Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1526 Webcam Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Webcam Replacement, Keyboard: adım 2, 1 resimden 1.
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Webcam Replacement: adım 3, 1 resimden 1.
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Webcam Replacement: adım 4, 1 resimden 1.
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Webcam Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Webcam Replacement: adım 6, 2 resimden 1. Dell Inspiron 1526 Webcam Replacement: adım 6, 2 resimden 2.
    • Remove the control cover.
  7. Dell Inspiron 1526 Webcam Replacement: adım 7, 1 resimden 1.
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Webcam Replacement: adım 8, 1 resimden 1.
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Webcam Replacement: adım 9, 2 resimden 1. Dell Inspiron 1526 Webcam Replacement: adım 9, 2 resimden 2.
    • Remove the keyboard.
  10. Dell Inspiron 1526 Webcam Replacement, Screen: adım 10, 2 resimden 1. Dell Inspiron 1526 Webcam Replacement, Screen: adım 10, 2 resimden 2.
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Webcam Replacement: adım 11, 3 resimden 1. Dell Inspiron 1526 Webcam Replacement: adım 11, 3 resimden 2. Dell Inspiron 1526 Webcam Replacement: adım 11, 3 resimden 3.
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Webcam Replacement: adım 12, 2 resimden 1. Dell Inspiron 1526 Webcam Replacement: adım 12, 2 resimden 2.
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
  13. Dell Inspiron 1526 Webcam Replacement, Webcam: adım 13, 2 resimden 1. Dell Inspiron 1526 Webcam Replacement, Webcam: adım 13, 2 resimden 2.
    • Detach the webcam connector.
  14. Dell Inspiron 1526 Webcam Replacement: adım 14, 1 resimden 1.
    • From both sides, pry and pull upwards from the back of the display cover.
    • This module has no screws affixing it to the display cover; it is held in by snapping it into the plastic brackets.
Sonuç
Ahmed Alshamsi
181 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 201
