Ana içeriğe geç
Dell Inspiron 1545 Center Control Cover Replacement
  1. Dell Inspiron 1545 Center Control Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Center Control Cover Replacement: adım 2, 1 resimden 1.
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Center Control Cover Replacement: adım 3, 1 resimden 1.
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Center Control Cover Replacement, Center Control Cover: adım 4, 1 resimden 1.
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Center Control Cover Replacement: adım 5, 1 resimden 1.
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Center Control Cover Replacement: adım 6, 3 resimden 1. Dell Inspiron 1545 Center Control Cover Replacement: adım 6, 3 resimden 2. Dell Inspiron 1545 Center Control Cover Replacement: adım 6, 3 resimden 3.
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Lemay
3.037 İtibar
15 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G14
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,572
