Ana içeriğe geç
Dell Inspiron 1545 Computer Processing Unit Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: adım 1, 1 resimden 1.
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: adım 2, 1 resimden 1.
    • Slide the release latch while simultaneously pulling backwards on the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: adım 3, 1 resimden 1.
    • Slide the battery out of the battery bay.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: adım 4, 1 resimden 1.
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: adım 5, 2 resimden 1. Dell Inspiron 1545 Computer Processing Unit Replacement: adım 5, 2 resimden 2.
    • Carefully lift the base cover vertically away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: adım 6, 1 resimden 1.
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: adım 7, 1 resimden 1.
    • Pull up on the Heat Sink unit to remove it.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: adım 8, 1 resimden 1.
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: adım 9, 1 resimden 1.
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Nathan Lemay
3.160 İtibar
15 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G14
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 3,275
