Ana içeriğe geç
Dell Inspiron 1545 Display Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1545 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 1545 Display Replacement: adım 2, 1 resimden 1.
    • Slide the release latch while simultaneously pulling backwards on the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 1545 Display Replacement: adım 3, 1 resimden 1.
    • Slide the battery out of the battery bay.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 1545 Display Replacement, Center Control Cover: adım 4, 1 resimden 1.
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 1545 Display Replacement: adım 5, 1 resimden 1.
    • Flip the laptop over to the front and open the display as far as possible.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 1545 Display Replacement: adım 6, 3 resimden 1. Dell Inspiron 1545 Display Replacement: adım 6, 3 resimden 2. Dell Inspiron 1545 Display Replacement: adım 6, 3 resimden 3.
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Inspiron 1545 Display Replacement, Keyboard: adım 7, 1 resimden 1.
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Inspiron 1545 Display Replacement: adım 8, 1 resimden 1.
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Inspiron 1545 Display Replacement: adım 9, 1 resimden 1.
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    FixBot'a Sor
    Yorum Ekle
  10. Dell Inspiron 1545 Display Replacement: adım 10, 1 resimden 1.
    • Lift the keyboard up and away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Inspiron 1545 Display Replacement, Display: adım 11, 1 resimden 1.
    • Remove the two screws (5.5mm, Phillips #1) from the laptop base.
    FixBot'a Sor
    Yorum Ekle
  12. Dell Inspiron 1545 Display Replacement: adım 12, 1 resimden 1.
    • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
    • Unwind the wires so they can be freely pulled through in the next step.
    FixBot'a Sor
    Yorum Ekle
  13. Dell Inspiron 1545 Display Replacement: adım 13, 1 resimden 1.
    • Turn the laptop over to its standard position.
    • Disconnect the Wed cable and Camera1 cable from the respective Motherboard connectors as marked. Unsecure the wires so they are loose.
    • Pull the black and white wires previously connected to the WLAN through the hole.
    FixBot'a Sor
    Yorum Ekle
  14. Dell Inspiron 1545 Display Replacement: adım 14, 1 resimden 1.
    • Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
    • Remove the four screws (5mm Phillips #1) (two on either side) that secure the display assembly.
    FixBot'a Sor
    Yorum Ekle
  15. Dell Inspiron 1545 Display Replacement: adım 15, 1 resimden 1.
    • Lift the display assembly off the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Nathan Lemay
3.160 İtibar
15 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G14
4 Üyeler
3Kılavuz Yorumları
wow that is really good
Mck - Isolutions - Yanıt Paylaş
AWESOME, but how to know if display is faulty or some issue in the other device causing blank screen
Kumar Bhrigu - Yanıt Paylaş
put it back toghther, then plug in a external monitor
Feyrowan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 51
Her zaman: 6,464
