Ana içeriğe geç
Dell Inspiron 1545 Keyboard Replacement
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Keyboard Replacement: adım 3, 1 resimden 1.
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: adım 4, 1 resimden 1.
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The screws are connected to the base cover by a washer anddo not remove from the base cover.
  5. Dell Inspiron 1545 Keyboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 1545 Keyboard Replacement: adım 5, 2 resimden 2.
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: adım 6, 1 resimden 1.
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  7. Dell Inspiron 1545 Keyboard Replacement: adım 7, 1 resimden 1.
    • Flip the laptop over to the front and open the display as far as possible.
  8. Dell Inspiron 1545 Keyboard Replacement: adım 8, 3 resimden 1. Dell Inspiron 1545 Keyboard Replacement: adım 8, 3 resimden 2. Dell Inspiron 1545 Keyboard Replacement: adım 8, 3 resimden 3.
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: adım 9, 1 resimden 1.
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  10. Dell Inspiron 1545 Keyboard Replacement: adım 10, 1 resimden 1.
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  11. Dell Inspiron 1545 Keyboard Replacement: adım 11, 1 resimden 1.
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  12. Dell Inspiron 1545 Keyboard Replacement: adım 12, 1 resimden 1.
    • Lift the keyboard up and away from the laptop.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Nathan Lemay
3.037 İtibar
15 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G14
4 Üyeler
2 Yorum
Step 4 and 5 are not needed.
James Thrun - Yanıt
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 6,686
