Giriş
This guide will allow you to remove the speakers if there is a physical malfunction with your speakers. This guide should only be used if you are certain there is a physical issue with the speakers.
Neye ihtiyacın var
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
Unsecure the wires from the routing guides so they are loose.
Remove four speaker screws (3mm Phillips #1). Each speaker has two.
Disconnect the speaker cable from the connector on the Motherboard by pulling the white plastic tab towards the screen.
Pull off the black tape securing the speaker cable.
2 farklı kişi bu kılavuzu tamamladı.
