Ana içeriğe geç
Dell Inspiron 1564 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1564 Display Assembly Replacement, Note the Routing: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note of the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Dell Inspiron 1564 Display Assembly Replacement, Remove the Screws: adım 2, 1 resimden 1.
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Dell Inspiron 1564 Display Assembly Replacement, Pull the Cables: adım 3, 1 resimden 1.
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 1564 Display Assembly Replacement, Note the Routing: adım 4, 1 resimden 1.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Dell Inspiron 1564 Display Assembly Replacement, Disconnecting the Display Cable: adım 5, 1 resimden 1.
    • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
  6. Dell Inspiron 1564 Display Assembly Replacement, Removing the Screws: adım 6, 1 resimden 1.
    • Hold the display assembly in place and remove the three screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1564 Display Assembly Replacement, Lifting the Display Assembly: adım 7, 1 resimden 1.
    • Lift the display assembly off the alignment posts on the computer base.
  8. Dell Inspiron 1564 Display Assembly Replacement, Placing the Display Assembly: adım 8, 1 resimden 1.
    • Use the alignment posts to place the display assembly on the computer base.
  9. Dell Inspiron 1564 Display Assembly Replacement, Replace the Screws: adım 9, 1 resimden 1.
    • Replace the three screws that secure the display assembly to the computer base
  10. Dell Inspiron 1564 Display Assembly Replacement, Connecting the Display Cable: adım 10, 1 resimden 1.
    • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
  11. Dell Inspiron 1564 Display Assembly Replacement, Routing the Antenna Cables: adım 11, 1 resimden 1.
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  12. Dell Inspiron 1564 Display Assembly Replacement, Thread the Cables: adım 12, 1 resimden 1.
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  13. Dell Inspiron 1564 Display Assembly Replacement, Replace the Screws: adım 13, 1 resimden 1.
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Bitiş Çizgisi
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,116
