Ana içeriğe geç
Dell Inspiron 1564 Memory Module Replacement
  1. Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: adım 1, 2 resimden 1. Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: adım 1, 2 resimden 2.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 1564 Memory Module Replacement, Remove the Memory Module: adım 2, 1 resimden 1.
    • Remove the memory module from the memory module connector.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 1564 Memory Module Replacement, Align the Notch: adım 3, 1 resimden 1.
    • Align the notch in the memory module with the tab in the memory module connector.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 1564 Memory Module Replacement, Sliding the Memory Module: adım 4, 1 resimden 1.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Terrence15
80.125 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 479
