Ana içeriğe geç
Dell Inspiron 15R 5520 Display Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15R 5520 Display Replacement, Battery: adım 1, 1 resimden 1.
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip device on its back displaying the battery.
  2. Dell Inspiron 15R 5520 Display Replacement: adım 2, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 2, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement: adım 2, 3 resimden 3.
    • Place a finger on both latches and push outwards.
    • Grab by the lip and pull upwards to remove battery.
  3. Dell Inspiron 15R 5520 Display Replacement, Display: adım 3, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement, Display: adım 3, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement, Display: adım 3, 3 resimden 3.
    • Lay the device as shown on table.
    • Use the plastic opening tool to separate the plastic casing on all sides.
  4. Dell Inspiron 15R 5520 Display Replacement: adım 4, 2 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 4, 2 resimden 2.
    • Remove casing for screen.
  5. Dell Inspiron 15R 5520 Display Replacement: adım 5, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 5, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement: adım 5, 3 resimden 3.
    • Locate and remove the top two 4mm screws.
  6. Dell Inspiron 15R 5520 Display Replacement: adım 6, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 6, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement: adım 6, 3 resimden 3.
    • Locate and remove the three 3mm left hand side screws.
  7. Dell Inspiron 15R 5520 Display Replacement: adım 7, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 7, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement: adım 7, 3 resimden 3.
    • Locate and remove the three 3mm right hand side screws.
  8. Dell Inspiron 15R 5520 Display Replacement: adım 8, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 8, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement: adım 8, 3 resimden 3.
    • Lift the display up to reveal the cable behind it.
    • Pull the cable straight down.
  9. Dell Inspiron 15R 5520 Display Replacement: adım 9, 3 resimden 1. Dell Inspiron 15R 5520 Display Replacement: adım 9, 3 resimden 2. Dell Inspiron 15R 5520 Display Replacement: adım 9, 3 resimden 3.
    • Sit the device upright and lay the display down on the keyboard.
    • Locate the cable on the base of the display.
    • Pull gently away from yourself.
  10. Dell Inspiron 15R 5520 Display Replacement: adım 10, 1 resimden 1.
    • Remove screen.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
zAj
484 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-1, Blackwell Fall 2016 USF Tampa, Team 18-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 2,575
