Giriş
In this guide, we will be showing you how to remove and replace the Memory Module.
Neye ihtiyacın var
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
2 Yorum
I took apart my dell inspiron 15r 5520 to replace the Wi-Fi card & now the touchpad & buttons will not work. What might have I done wrong?
الكمبيوتر يصدر صفاره عدد اربعه ولا يقلع
النظام
