Ana içeriğe geç
Dell Inspiron 15R 5521 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15R 5521 Memory Module Replacement, Loosen the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15R 5521 Memory Module Replacement, Lifting the Memory Module: adım 2, 1 resimden 1.
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15R 5521 Memory Module Replacement, Popping up the Memory Module: adım 3, 1 resimden 1.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Inspiron 15R 5521 Memory Module Replacement, Remove the Memory Module: adım 4, 1 resimden 1.
    • Remove the memory module from the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  5. Dell Inspiron 15R 5521 Memory Module Replacement, Sliding the Memory Module: adım 6, 1 resimden 1.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  6. Dell Inspiron 15R 5521 Memory Module Replacement, Slide the Tabs: adım 7, 1 resimden 1.
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  7. Dell Inspiron 15R 5521 Memory Module Replacement, Tighten the Screw: adım 8, 1 resimden 1.
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Bitiş Çizgisi
Terrence15
79.161 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.988 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 217
