Ana içeriğe geç
Dell Inspiron 15R Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15R Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over and locate the battery.
  2. Dell Inspiron 15R Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 2, 2 resimden 2.
    • Place thumbs on each latch and push outwards.
  3. Dell Inspiron 15R Keyboard Replacement: adım 3, 1 resimden 1.
    • Push and slide the battery away from you.
  4. Dell Inspiron 15R Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Dell Inspiron 15R Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Dell Inspiron 15R Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
  5. Dell Inspiron 15R Keyboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 5, 2 resimden 2.
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
  6. Dell Inspiron 15R Keyboard Replacement: adım 6, 1 resimden 1.
    • Turn the device around and open it up.
  7. Dell Inspiron 15R Keyboard Replacement: adım 7, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 7, 2 resimden 2.
    • Using your index finger, push down on the F1 and F7 keys.
  8. Dell Inspiron 15R Keyboard Replacement: adım 8, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 8, 2 resimden 2.
    • Using your index finger, push down on the x icon and Home keys.
  9. Dell Inspiron 15R Keyboard Replacement: adım 9, 3 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 9, 3 resimden 2. Dell Inspiron 15R Keyboard Replacement: adım 9, 3 resimden 3.
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
  10. Dell Inspiron 15R Keyboard Replacement: adım 10, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 10, 2 resimden 2.
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
  11. Dell Inspiron 15R Keyboard Replacement: adım 11, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 11, 2 resimden 2.
    • Carefully pull and turn the keyboard over.
  12. Dell Inspiron 15R Keyboard Replacement: adım 12, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 12, 2 resimden 2.
    • Lift the black lever.
  13. Dell Inspiron 15R Keyboard Replacement: adım 13, 2 resimden 1. Dell Inspiron 15R Keyboard Replacement: adım 13, 2 resimden 2.
    • Remove the keyboard cable
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trixie Gonzalez
843 İtibar
6 adet Kılavuz yazıldı
Ekip
San Diego State, Team 2-2, Sheppard Winter 2015 San Diego State, Team 2-2, Sheppard Winter 2015 üyesi
SDSU-SHEPPARD-W15S2G2
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,335
