Giriş
In this guide, we will be showing you how to remove and replace the Memory Module.
Neye ihtiyacın var
Close the display and turn the computer over.
Loosen the captive screw that secures the memory-module cover to the computer base.
Using your fingertips, lift the memory-module cover out of the slots on the computer base.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
Tighten the captive screw that secures the memory-module cover to the computer base.
