Ana içeriğe geç
Dell Inspiron 17 N7010 BIOS Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: adım 1, 1 resimden 1.
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: adım 2, 3 resimden 1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: adım 2, 3 resimden 2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: adım 2, 3 resimden 3.
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: adım 3, 1 resimden 1.
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: adım 4, 2 resimden 1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: adım 4, 2 resimden 2.
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: adım 5, 1 resimden 1.
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Joseph Sctbunio
7.416 İtibar
42 adet Kılavuz yazıldı
7 Yorum
thanks for your help!!!
E P - Yanıt
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - Yanıt
Thanks for the instructions. Computer starts up great now.
jkleinjans - Yanıt
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 102
Her zaman: 18,145
