Ana içeriğe geç
Dell Inspiron 17-3721 CMOS Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: adım 1, 3 resimden 1. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: adım 1, 3 resimden 2. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: adım 1, 3 resimden 3.
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 CMOS Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-3721 CMOS Battery Replacement: adım 2, 2 resimden 2.
    • Remove the CMOS battery with the plastic opening tools.
    • Be careful while prying it open, the battery holder can break if you use too much force.
    • Do not use metal tools when touching anything that can have an electric charge.
Sonuç
Christopher Meninno
296 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 941
