Ana içeriğe geç
Dell Inspiron 17-3721 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-3721 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove the two 5.5 mm PH1 Phillips head screws holding in the hard drive.
    • Slide the hard drive out of its slot and lift it out of the device.
    • At the time of the creation of this guide, our device did not include a hard drive.
Sonuç
Kevin Prairie
445 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 965
