Ana içeriğe geç
Dell Inspiron 17-3721 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-3721 Keyboard Replacement: adım 2, 2 resimden 2.
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Prairie
445 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G3
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Wow that was easy! Thanks :D
Isaac Pettis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 421
