Ana içeriğe geç
Dell Inspiron 17-3721 Optical Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: adım 1, 2 resimden 1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: adım 1, 2 resimden 2.
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-3721 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 17-3721 Optical Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 17-3721 Optical Drive Replacement: adım 4, 3 resimden 3.
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Prairie
445 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 309
