Ana içeriğe geç
Dell Inspiron 17-5748 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 17-5748 Keyboard Replacement: adım 5, 2 resimden 2.
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: adım 6, 2 resimden 1. Dell Inspiron 17-5748 Keyboard Replacement: adım 6, 2 resimden 2.
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: adım 7, 2 resimden 1. Dell Inspiron 17-5748 Keyboard Replacement: adım 7, 2 resimden 2.
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
Sonuç
Justine Vaca
121 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 632
