Ana içeriğe geç
Dell Inspiron 17-5748 Speakers Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5748 Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Speakers Replacement: adım 2, 1 resimden 1.
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Speakers Replacement: adım 3, 1 resimden 1.
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Speakers Replacement, Speakers: adım 4, 3 resimden 1. Dell Inspiron 17-5748 Speakers Replacement, Speakers: adım 4, 3 resimden 2. Dell Inspiron 17-5748 Speakers Replacement, Speakers: adım 4, 3 resimden 3.
    • Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
    • Slide the Optical Drive out of the device.
  5. Dell Inspiron 17-5748 Speakers Replacement: adım 5, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 5, 2 resimden 2.
    • Remove the two 4.5 mm Phillips #0 screws on the access panel door.
  6. Dell Inspiron 17-5748 Speakers Replacement: adım 6, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
  7. Dell Inspiron 17-5748 Speakers Replacement: adım 7, 3 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 7, 3 resimden 2. Dell Inspiron 17-5748 Speakers Replacement: adım 7, 3 resimden 3.
    • Remove the 2.5 mm Phillips #0 screw securing the hard drive.
    • Slide the hard drive out using the pull tab.
    • Remove the hard drive from the device.
  8. Dell Inspiron 17-5748 Speakers Replacement: adım 8, 1 resimden 1.
    • Open the laptop and locate the keyboard.
  9. Dell Inspiron 17-5748 Speakers Replacement: adım 9, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 9, 2 resimden 2.
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  10. Dell Inspiron 17-5748 Speakers Replacement: adım 10, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 10, 2 resimden 2.
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  11. Dell Inspiron 17-5748 Speakers Replacement: adım 11, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 11, 2 resimden 2.
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
  12. Dell Inspiron 17-5748 Speakers Replacement: adım 12, 1 resimden 1.
    • Remove the five 4.5 mm Phillips #0 screws found under the keyboard.
  13. Dell Inspiron 17-5748 Speakers Replacement: adım 13, 3 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 13, 3 resimden 2. Dell Inspiron 17-5748 Speakers Replacement: adım 13, 3 resimden 3.
    • Do not fully remove the palm rest until the ribbon cable underneath is detached.
    • Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
    • Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
    • Remove the palm rest from the device.
  14. Dell Inspiron 17-5748 Speakers Replacement: adım 14, 3 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 14, 3 resimden 2. Dell Inspiron 17-5748 Speakers Replacement: adım 14, 3 resimden 3.
    • Locate the first speaker.
    • Unplug the speaker cable.
  15. Dell Inspiron 17-5748 Speakers Replacement: adım 15, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 15, 2 resimden 2.
    • Lift the speaker from the corner.
    • Remove the speaker.
  16. Dell Inspiron 17-5748 Speakers Replacement: adım 16, 2 resimden 1. Dell Inspiron 17-5748 Speakers Replacement: adım 16, 2 resimden 2.
    • Using the plastic opening tool, gently remove the second speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bradley
235 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 526
