Ana içeriğe geç
Dell Inspiron 17-5749 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5749 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 17-5749 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-5749 Hard Drive Replacement: adım 2, 2 resimden 2.
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: adım 3, 3 resimden 1. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: adım 3, 3 resimden 2. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: adım 3, 3 resimden 3.
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Tran
1.162 İtibar
12 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 25
Her zaman: 739
