Ana içeriğe geç
Dell Inspiron 17-5749 Heat-sink Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 2, 2 resimden 2.
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Back Cover: adım 3, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Back Cover: adım 3, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Back Cover: adım 3, 3 resimden 3.
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Optical Drive: adım 4, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Optical Drive: adım 4, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Optical Drive: adım 4, 3 resimden 3.
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  5. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 5, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 5, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 5, 3 resimden 3.
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
  6. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Hard Drive: adım 6, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Hard Drive: adım 6, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Hard Drive: adım 6, 3 resimden 3.
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
  7. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Wireless Card: adım 7, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Wireless Card: adım 7, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Wireless Card: adım 7, 3 resimden 3.
    • Disconnect the antenna cables from the wireless card.
    • Push the securing tab to release the wireless card.
    • Slide the wireless card out of the wireless-card slot.
  8. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Keyboard: adım 8, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Keyboard: adım 8, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Keyboard: adım 8, 3 resimden 3.
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  9. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 9, 1 resimden 1.
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
  10. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Palm Rest: adım 10, 2 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Palm Rest: adım 10, 2 resimden 2.
    • Remove the (5) 5.5mm screws that secure the palm rest to the system board.
    • Close the display and turn the computer over.
    • Remove the (10) 5.5mm screws that secure the palm rest to the computer base.
  11. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 11, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 11, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 11, 3 resimden 3.
    • Turn the computer over and open the display as far as possible.
    • Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
    • Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
    • Lift the palm rest away from the display assembly.
  12. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Optical-Drive Connector Board: adım 12, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Optical-Drive Connector Board: adım 12, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Optical-Drive Connector Board: adım 12, 3 resimden 3.
    • Remove the 2.5mm screw that secures the optical-drive connector board to the computer base.
    • Move wireless card wires covering the board away from the board.
    • Slide the optical-drive connector board away from the computer base.
    • Lift the optical-drive connector board away from the computer base.
  13. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Battery-Connector Board: adım 13, 2 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Battery-Connector Board: adım 13, 2 resimden 2.
    • Remove the 5.5mm screws that secure the battery-connector board to the computer base.
    • Carefully lift the battery-connector board to disconnect it from the system board.
  14. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, System Board: adım 14, 2 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, System Board: adım 14, 2 resimden 2.
    • Remove the antenna cables from the routing guides on the computer base.
    • Slide the antenna cables through the slot on the computer base.
  15. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 15, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 15, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 15, 3 resimden 3.
    • Peel off the tape that secures the display cable to the system-board assembly.
    • Lift the connector latch and disconnect the display cable from the system board.
    • Lift the connector latch and disconnect the I/O board cable from the system board.
  16. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 16, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 16, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement: adım 16, 3 resimden 3.
    • Disconnect the speaker cable from the system board.
    • Disconnect the power-adapter port cable from the system board.
    • Remove the 5.5mm screws that secure the system-board assembly to the computer base.
    • Lift the system-board assembly off the computer base.
  17. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Heat-sink Assembly: adım 17, 3 resimden 1. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Heat-sink Assembly: adım 17, 3 resimden 2. Dell Inspiron 17-5749 Heat-sink Assembly Replacement, Heat-sink Assembly: adım 17, 3 resimden 3.
    • Turn the system-board assembly over and place it on a flat and clean surface.
    • In sequential order (indicated on the heat sink), loosen the (3) captive 5.5mm screws that secure the heat-sink assembly to the system board.
    • Disconnect the fan cable from the system board.
    • Lift the heat-sink assembly off the system board.
Sonuç
Christopher Tran
1.162 İtibar
12 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 197
